Suzuki DT 25/30 Throttle positioning sensor adjustment confusion
lake vermilion
Can anyone shed light on the Suzuki Throttle Position Sensor wiring as fitted to early 90’s DT25/30/55/60? –The Clymer Manual I have has contradictory info, and if my theory is correct, I have a knackered TPS
The “sensor test” section of Clymer implies there are 4 wires coming out the sensor as follows:
3 to a black plug (black / red stripe, light green / red stripe and black.) and a fourth separate
black wire with a crimped washer type connection.
Now, my Sensor on the engine agrees with the wiring diagram at the back of Clymer, namely as above, but no black wire to the 3 pin plug. (Plug still a 3 –pin, but the centre Black wire is not there, nor is the pin on either the sensor or the loom, and the space is filled with sealant)
My question is – can anyone confirm whether the two black wires on the “4 wire” sensor are connected together inside the sensor? The test described uses the 3 pins of the plug leaving the "foutrth wire" free, and so I assumed I could use the “free” black cable on mine to do the test instead of the black in the plug. This is on a '93 vintage DT25, I suspect an earlier incarnation of the TPS was used on something that required both a dedicated and “global” earth connection, hence the extra black cable.
I have worked out form the info I have available that the wires appear to be:
Black – Earth
Black / red stripe +V
Light Green / Red stripe - signal to Cdi
If this is correct, then my TPS is gubbed. If not, could anyone enlighten me as to the appropriate test voltages & pins?
Thanks.
I posted the wiring colours for you there FYI .... I'm suppose to be a master at the 30hp Suzuki 2-stroke but I must be honest I only ever had the tiller versions as I raced this motor. That, and it has been many years since I last worked on a suzuki. From the other suzuki's I have owned I have replaced the TPS at least once on each of them so if you are having issues I would suggest just replacing it ... brownspoint.com
Thank You for the response. I will replace it
