the_last_hour
Hi guys need some help once again.
twin 5.7 carbed 2006 crusaders w/ edelbrock 1409 electric choke.....
The port motor will not start, starboard will. Fuel valves have been set so both engines pull off of both tanks without isolating them. After cranking FOREVER, with a push of the throttle and flame arrestor off, I see no fuel squirting into the carb. Comparing the other motor, I see fuel squirting. Also i hear and feel no vibration from port fuel pump when the ignition switch is ON, with the star ignition switch on I hear the pump and feel it. I haven't checked for voltage at the pump yet. I'm asssuming the pump is dead, but I'm confused about the relationship of the oil pressure switch to pump. If the oil pressure switch is dead, will it prevent the fuel pump from running in this situation. Do I need to test both?
Finally, what exactly is the procedure to fill the carb bowls prior to turning the engines over so I don't have to crank FOREVER when I've been away from the boat for a few weeks? The pumps are electric and I know FastJeff has explained to me before how to do this but I forgot. Please explain. Thanks again for all the help.
Steve
Steve
