baywrangler
Here's a new one, when I turn the key switch to the on position I get the normal two beeps. Leaving the key in that position, without turning the motor over, I get a long intermittent alarm with a blinking overheat light on the four light ignition switch.
So far I have put a shunt in to check codes but don't have any sequence on the MIL light. I cycled the kill switch five times to reset the system, heard the confirmation beep, and tried again. Same thing, two healthy beeps following by the on & off long buzzer with a blinking overheat light. In all instances, the oil light comes on green and then goes off, but this is all happening without turning over the motor. I did turn it over once and the beeping continued like this.
Any thoughts? I don't see anything in the service manual so am on the verge of taking it to a mechanic to diagnose...
