Stop switch/lanyard retro-fit to '81 J5?
I have an '81 J5RCIC and want to replace the existing kill switch with a safety lanyard type switch.
Looking through the parts diagrams I see that 1987 was the first year for these, any idea if the new switch would fit?
Any other solution? Aftermarket?
Model #J5RCIC is indeed a 4.5hp Johnson.
The parts manual is a 1987 what? Trying to get a idea of what this kill switch you speak of looks like.
A kill switch would normally connect (on a power-pack equipped engine) between the Black/Yellow wire (kill circuit) and a ground. If a lanyard equipped kill switch, having the land-yard yanked OFF would ground and kill the ignition.
That kill switch 398692 has a ridiculous price of approximately $115 on it! Those people have got to be out of their mind!
Any two wire kill switch at a fraction of that price, wired as follows, would do the job.
A kill switch would normally connect (on a power-pack equipped engine) between the Black/Yellow wire (kill circuit) and a ground. A lanyard equipped kill switch, having the land-yard yanked OFF would ground and kill the ignition.
[h=2]Sierra MP28870 Emergency Cut-Off Switch[/h]
$13.72 [SUP]$[/SUP] 13 [SUP]72[/SUP] Prime
Only 19 left in stock - order soon.
Any idea if those generic switches push to stop as well like the OEM ones?
I'd hate to have to pull the clip out every time I want to kill the engine.
I just assumed that you wanted to rig a kill switch to kill the engine in case you fell overboard.
Any 2 wire push button switch would do the job BUT you need to be aware of which ones would put up with the water spray.... That aspect I have no idea about.
Yes they do. I have a ‘79 evinrude 9.9 that only had a push button kill switch. I replaced it with a generic kill switch/lanyard and you can push in the button to stop the engine.
KJ
KJ
Sweet! Got a part no., link, manufacturer, any of the above? :p
Did it directly replace the existing switch or did you have to make it work?
Just to update an old thread, hopefully this helps someone.
I got one of the cheap kill switches, it would have worked but to fit it in the handle would be a PITA. Good news is the newer switch part # 0398692 drops right in. They're pricey but I found one a little cheaper on FleeBay.
