bowhuntrrl
"I bought a boat late last sea
"I bought a boat late last season, it had been sitting for 4-5 years. I went through the whole darn engine. I rebuilt the carbs, replaced the fuel pump diaphragm and o rings, replaced the plugs, replaced the fuel filters (engine and separator), checked the timing, cleaned the oil tank and put in new oil.
The engine starts and runs great. I can idle on the lake all day, or run at lower rpm. Once I crank it up to WOT, the boat runs about 5 minutes before it starts to die. If I pump the bulb, it takes off again. I've double checked the fuel pump and see no problems with it. I was told that the engine connector fitting can leak air, so I removed it from the system by using a double sided brass fuel barb and hose clamps. I also removed the boats in-hull fuel tank by hooking an external tank directly to the engine (bypassing the separator. It still does it. I really need to get a handle on this since the season is almost here in Massachusetts.
I know it's a fuel supply problem, I just can't figure out what it is. The only thing left is to replace the bulb. Does that seem logical or whatever other suggestion would anyone make??? This one has me baffled.Thanks."
