I sent my stator test reults to outboardignition.com and the following is what they just sent to me.
Please understand that I couldn’t give a guarantee that the stator is bad, but is does sound like it could be. The blue blue/white
wires are the high output side of the stator and its reading out of range. In that case, they suggest replacing it.
The red red/white wires are the low side and fire the motor at lower rpm, then at around 2500 to 3000 rpm and above, it switches to
the high side (blue blue/white).
Donna
If you burned up the regulator, it may have damaged the stator in the process
>(they are directly connected). That could well cause a
> weak spark if the stator output is low. You can ohms the stator according to
>our guide and see if that shows anything before just
> guessing at it.
Donna
> guessing at it.
