I have a 86 Glastron Carlson C
I have a 86 Glastron Carlson CVX16 with a 86 Merc 115 Hp with a Quicksilver Throttle set. Last night when I put it in the water the battery was kinda low from a switch being left on. Then it just quit turning over. I checked the starter and it is fine. I was able to arc across the stater relay and the motor would turn over. But the key will not turn it over. I can hear the choke still work but will not turn over. Is it possible that the starter relay is still bad even if i was able to arc across it. Or would it be the key switch. Thanks in advanced.
