Your going to find that engine is always gonna be a byatch to start.
But maybe we can help you make it a little easier.
1- Your starter the old type or new type ? New type uses less juice, just a better starter.
2' Your idle circuit clean in the carb ?
3- Choke working correctly ? Should be closed when cold. Choke should open all the way when hot.
4- Fuel pressure? What is the pump giving you in psi ? 4-7 no less no more.
5- Spark ? Your engine has the crank mounted gen ? I consider that a gen not a alternator. There are upgrade kits to do away with the old style gen and install a modern alt. You have a good spark to the plugs ?
Dist., wires... was going to put this under spark then thought ignition, i left it in the middle. Points good, wires good, no play in the dist. shaft ? Wiggle the shaft if there's wiggle it got to go. Also you got to gap the points every year, and lightly sand em'.
6- Ignition ! We need good juice starting from the battery with good cables, no green ends under the rubber ! We need a good ground to the block on the neg side !
Disconnect the battery cables, follow the cable to each juncture and remove and clean shiny all connections, including the starter.
The main barrel plug held together with a spring clip , take it apart look in the holes, green is bad. Clean it up, I actually went straight with the wires and took the barrel plug completely out. It's what i did i'm not telling you to do it, it's WHAT I DID WITH MY BOAT.
How to run a carbed engine : Post #7
http://www.marineengine.com/boat-forum/showthread.php?t=380996
