" It has an electric starter ,
" It has an electric starter ,after a few times of trying to start it ,with about 10 rotations of the motor per try,the speed of the starter slows noticeably.even with a fully charged battery.I changed the battery cables to the solenoid but not the one from the solenoid to the starter since it is in a harness.I did take off the ends of the cable from the starter to the solenoid and cleaned them for a good connection but the cable is old and shows it.I have been thinking about bypassing it with another cable but this cable is thicker than the ones I have seen ,and I am not sure if it is a bad starter and the cable is doing its job fine.Has anyone had this problem or know what I should do to correct it?Any help is greatly appreciated. Mike "
