HarryCarry
While trying to start my port 454 Crusader it was cranking like normal then click. The starter engages but does not spin. I checked battery connection, ground connection, voltage and all were good. I tapped the starter a bunch of times with a hammer, but still won't spin. I noticed movement from the bendix spring and some smoke coming out of the hole in the bendix case where the spring is after several attempts to start. My next thought is to turn the engine to see if the problem is with the flywheel. What's the best way to do this? Any advice would be much appreciated.
