History; Water in out drive ruined gears. Shop located a used drive and installed it. Also had the bellows and water lines replaced while the drive was off. Speedo worked before repairs made and was even reasonably accurate when compared to GPS.
On my test run everything seems to be working well except no speedo. When I pulled the boat I checked the speedo coupler from the transom to the drive and it is firmly connected.
Now I figure it's one of two things. Either the pitot/tube in the drive is clogged or the tube from the transom to the speedo is pinched. Since the "new" drive is used and looks like it lived in the water I'm going to clean the entry hole and maybe blow compressed air through it. To check the thru transom line I thought I might use compressed air there too. I just don't know how high a pressure to use.
So that's my plan, any other suggestions or things to check for?
