Spark plugs
jerry101
i have a 7.5 hsp mercury 1983
i have a 7.5 hsp mercury 1983 model ser #6241553 can anybody tell me what number spark plug it takes and setting also what the compression should be ?
"Hi Gerald,champion says L77JC
"Hi Gerald,champion says L77JC4,1mm gap.NGK says B9HS-10,1mm gap.My 18hp 1984 gets 140 psi,cold,wide open throttle,if thats any help"
"thanks so much ian...could yo
"thanks so much ian...could you tell me what 1mm would be in thousands, and how much compression this motor should have..........thanks again jerry d"
"hi,1mm is roughly .040 thou.i
"hi,1mm is roughly .040 thou.i dont know the correct compression,but any thing over 120psi is not bad.also depends whether its done hot or cold.like i said,my 18hp gets 140psi cold,my 8hp johnson with decompression holes,gets 120psi,cold.my worn 25hp even got 120psi.hope thats some help"
Most outboard manufacturers do
Most outboard manufacturers dont give comp figs...however they do state that all compressions should be within 10% of each other.
