spark plug gap
I was told that the vortex motor the gap should be 50-60, just tryn to find the actual gap for this motor. There is iridium plugs in the motor.
You need to identify if it is a NON GEN II or a GEN II engine.
Non Gen II have 12 bolts to intake manifold.
Gen II have 8 bolts to intake manifold.
Here is what the manual specifies,
I was told that the vortex engine the gap should be 50-60, just tryn to find the actual gap for this engine. There are iridium plugs in the engine.
https://www.briskusa.com/spark_plug_gap_spark_plug_gap_chart
Nut shelling this, your ignition system (secondary coil voltage and amperage), fuel/air mixture, cylinder pressure, etc., will all determine the gap between the inner/outer electrode.
For example...... a .050" or .060" gap would be used for a HEI or high output ignition system.
Disregard that post.
You gap your spark plugs exactly to the OEM manufactures specifications. END OF STORY.
The only time you need to make adjustments to a spark plug gap is after heavily modifying engine.
F'n Pin head!
