erratic_outboard
I have a 1981 evinrude 25hp outboard, model e25rcIm which has run great for the past 10 years. But this year it only runs when it wants to. I’ve taken it out on the lake 4 times this year and the outboard will NOT start, despite me running it in a barrel the day before, each time. It runs great, low speed and full throttle, no fouling or stalling- and once I can get it started it’s good for the day. It doesn’t seem to want to start, it just turns over. I have to “fiddle” with it- pull the plugs (which look good) wipe them off, pull the cover off the fuel pump, etc, then eventually it will belch a little smoke and then start right up. This has never happened before, it’s always run like a trooper.
The engine has new NGK plugs, is getting gas, the fuel filter is clean, new fuel lines, strong deep cycle marine battery, and electric start. This model also has electronic ignition…
I took it out last Thursday and it would not start, despite me running it in the barrel at home the day before. So I pulled it out of the water and shined up all the electrical connections on the coils, etc, and dunked it again. Still no start.
Could it be bad coil(s)? I hate to start replacing parts that might be good, and we don’t have a good repair center here.
Please help- I’m not sure where to go from here and our boating season is short here in upstate NY!
Thank you!
Thank you!
