teg1928
Need some advice from someone experienced with these carbs. Had them (dual carbs) rebuilt awhile ago and just finishing the boat to get it in the water. It needed lots of repair. So as to basic carburator setup- My question is after installing the carbs, do I leave the throttle cable unattached and set the idle speed, then attach the throttle cable with the shifter in the neutral position? Additionally- I have found carburator setup info on many varieties of the AQ engine familyand various carburators, i.e. AQ131 , 230, 151, 250, 171, 251. but doesn't specifically list my AQ130C or my Solex 44 PAI carbs. My SELOC book does not provide much info on this particular carburator either. How many turns of the idle screws and idle mixture screws is recommended for this engine?
Additionally, How can I tell what outdrive I have as the cover plate with this detail is missing on the outdrive unit. My boat is a 1971 Glastron with AQ130 motor.
Any help is much appreciated.
Thanks,
Teg1928
Thanks,
Teg1928
