"Dan, given the importance of
"Dan, given the importance of ignition advance for our marine gassers, I'd recommend that you find and verify TDC # 1 on both engines.
This may require performing the Positive Piston Stop procedure.
It may be a hassle, but you do this just once!
I'd then make sure that you have a clear means of seeing and reading up to 30* in the ignition advance direction for both engines!
Use a Standard Ole "Strobe Type" timing light!
I'd not use a digitally advancing light for dynamic TAT for a Marine gasser! It is just too critical, IMO!
You will want to see Real Degrees in Real Time!
Again, IMO."
