I have a mercury 2007 50 ELPTO 2 stroke. When I first put in and crank up the motor cranks right up, runs fine, idles fine, and turns around 5600 RPM's. after running the motor for a while it starts acting up. It dosent idle good and dies sometimes when put in gear but the biggest thing is when I crank up and go full throttle sometimes it will go up to normal 5600 rpm's and sometimes it will only go up to around 3500 rpm's. when it only goes to the low rpm's if i leave it at full throttle it will run like that for a while then all of the sudden will take off as if i went from half to full throttle but I havent touched the throttle. sometimes it will do the low rpm thing and just have short spurts of normal for like 1-2 seconds then back to low then again all of the sudden take off. like I said this usually happens after a few hours on the water. I took the boat to the shop in the spring to have the fuel system cleaned and ready for summer so I dont think it is that. Also this dosent seem to me to be a constant miss. Please Help, where should I start?
