slow or no peeing at idle- pees ok with added throttle- is this normal?
No. Your impeller may possibly be worn or missing part of a blade.
Time to change your impeller. Also, take out the thermostat and backflush the system with a garden hose into the thermostat housing while the lower unit is off.
I have attached instructions for changing a water pump on an 8 or 9.9. The procedure would be the same. Pay close attention to the measurements on the shift shaft parts when you put it back together. Otherwise, the shifting will not be correct.
Mike
  • ml.repaw05v.water_pump_replacement_for_bf8d__bf9.9d_outboard_motors.pdf
