Hi Guys,
I just completed some minor carb work on a 1993 Sea ray with a 5.0 . The customer now states that there is a unusual amount of slack in the throttle once it is in gear. It goes in and out of gear normally without stalling, but you really have to push the throttle lever foward quite a bit before the carb. starts to open. It has a black plastic shifter with a red pull up button inside the top of the handle to allow for motion. It also has the trim switch on the body of the shifter not the actual handle. I suspect there is a problem in the shifter as it does shift ok with no stalling. You just have to push it forward farther than normal to get throttle. Is there any thing to look for inside the shifter box and if so how does one open it up?
Thanks,
Jon Allen
Thanks,
Jon Allen
