While checking all the connections on my 1987 Johnson 120 i decided to use a small wire wheel (hand held) to clean up some of the rust / corrosion on the regulator / rectifier body since it was exposed. Soon as I took a couple strokes it sparked similar to when you hook jumper cables up...I know I did not hit any wires sine they were on other side and under plastic box thing.
I then grabbed my voltmeter and saw there was current showing when I touched the metal body of the unit..again not the wires.
Should this happen or does this mean there's a problem somewhere (also I am having NO SPARK issue).
I have attached a photo of where I was cleaning and checked for current...it was more accessible then (this photo is older).
Thank you.
p.s. When I saw this I was hoping I would get spark again once I unplugged that unit but there was no change
Thank you.
