Fishingpcola
I replaced both my throttle and shifter cables back in May. Shifting was difficult then but better with new cables. You could not shift by hand when cables were disconnected. I'm told you should be able to shift using your hand on the shifter lever. I will be spraying with PB Blaster every day to loosen up. The service shop says my have to pull power head off and remove corroded parts to fix. Any suggestions.
