I bought an 80 Johnson 15hp(J15RLCSD) recently that wasn't pumping water. I pulled the lower unit and replaced the impellor. After I was done I tested the motor at a local lake for about an hour and had no problems. Yesterday I was running the motor wide open when I heard a pop and then it started slipping out of gear. I had to limp back to the boat ramp. It took an hour and a half as any amount of throttle caused the motor to slip out of gear again.
I've done some reading which indicated that the problem is most likely the clutch dog and forward gear UNLESS the shift linkage is out of adjustment. Is there somewhere to adjust the linkage on these motors besides the obvious coupler that must be removed to drop the LU? There is no adjustability there other than the possibility that it is not seated properly. I'm just looking to rule everything else out before dismantling the gearbox. Thanks for any help... Tom
