I accidentally removed the shift limit screw. Do you have any tricks for lining up and installing the shift limit screw, or do I need to pull the lower part of the housing off. Of course, if the lower part of the housing is removed, looks like the gasket will need to be replaced.
Right now, I have the gear housing removed to rebuild the water pump.
Any advice you have is appreciated. Thanks
