Shift Cable Bellows replacement
botaman
Folks,
While I'm going to do the bellows. What else should I replace while I'm in there? Thank you for all your help.
BTW, this is an 02 Larson 4.3 V6 Mercruiser.
Well,
Grease Gimbal bearing, and gimbal housing, prop, input shaft, clean pivot pins (for the trim cylinders-keeps them from getting corroded) Check condition of Upper Bellows. Lower bellows not as important(but still worth checking)
