"I see someone else had this i
"I see someone else had this issue recently
One of my AQ125B's stopped running while idling. I checked spark, fuel all was as it should be. So I cranked for about 20seconds and Seawater spewed from my carb. Tuned out my timing belt had jumped. After blowing the water out, wd40, ATF, and changing the timing belt It will not start. The compression which used to be about 150 accross the board is now 140, 90,90, 140. Would this mean that some sediment is still in the valves, thus not seating, or would as my mechanic suggested, not worth spending anymore time and money on?
I've just spent $20,000 on new transom and engine mounts - so I'm kinda into this boat, if you know what I mean."
