Seaking 5 info
jimp115
"i have a 1949 seaking 5 hp mo
"i have a 1949 seaking 5 hp model # 94gg9015a. compression was good so i replaced the impeller, plugs, wires, coils, cleaned the carb, and the tank and filter. the condensors were good and the points were also, so i just filed the points. i,m in the process of putting it back together. Was wondering if anyone knew what the torque specs on the flywheel nut are? Or if it is something that is not important. Also if there is anything that i missed in rebuilding this gem please let me know. Also i believe that the fuel mix is 24:1 does this sound correct? Thank you!!!!"
"Jim, I have a 1948 5hp Sea Ki
"Jim, I have a 1948 5hp Sea King. The plate that has the model numbers & serial Numbers says at the bottom of the plate the mixture ratio is 16 to 1 ."
