"I have an AQ131A and I Cant s
"I have an AQ131A and I Cant seem to figure out where my fresh water is going I fill the tank and let engine idle for 12 hour and tank stays full if I take the boat out for a 12 hour the water dissappears and boat starts overheating and slows down will not go over 3000 RPMI have checked all the hoses the water pump the thermostat housing around the head there is no water getting into the oil.I am running without a thermostat and using just water there is a slight leak in my raw water strainer but dont think that that has anything to do with it.Could I have a ruptured heat exchanger and when the pressure builds water is forced out and mixes with raw water,could it be escaping as steam through the radiator cap what rating should I get for a new cap.ANY HELP WOULD BE APPRECIATED THANKS!"
