"So, here I am still WORKING O
"So, here I am still WORKING ON the boat instead of RIDING IN the boat. I pulled the anti-siphon tube, it was clean. Widened the gap on the plugs to 0.035. I would love to see if that makes a difference, but now the engine won't start. Got a click on at the solenoid but no crank. I figured the battery was low because I left it on for a few days (the ignition was off, whew...) Charged the battery up, no change. The starter and solenoid are brand new, so I thought maybe it might be the relay. Bought a new one, put it on, solenoid clicked once and then the whole system died. No outdrive tilt, no tilt indicator light, no power to the instrument panel, no panel lights, not even a click at the solenoid. For all practical purposes, it seems as if the battery was taken out of the boat. Of course it hasn't, the bilge pump, blower, horn, depth finder, stereo and nav lights all work like a charm. So, I put the old relay back in, no change. The 40 Amp circuit breaker didn't trip and the giant inline fuse is intact.
Ideas anyone?
Thanks,
Chris
New Osco Exhaust Manifold
Replaced Cylinder Head
New Head Gasket
New Exhaust Manifold Gaskets
New Intake Manifold Gasket
New Valve Cover Gasket
New VP Thermostat
New Timing Belt
New Accessory Belt
New Pertronix Ignitor Ignition Module
New Pertronix Flame-Thrower Ignition Coil
New Mando Alternator
New Starter
New Bosch Distributor Cap
New Bosch Platinum Plugs .035
New Starter Relay"
