RPM Shooting
sayed
"Hi everybody
Can someone h
"Hi everybody
Can someone help please, my engine will hit at Max speed 7RPM is that ok ?
I thing my boat is small compare to my engine 200hp Yamaha, 19 feet boat, prop 19 inches.
If I want to replace the prop what size shall I put?
regards"
If you are actually turning 70
If you are actually turning 7000rpm with a 19p prop then you need to try a 25p. The Yamaha VMax HPDI has a Rev Limiter at 6200rpm.But it is best to keep it running between 5700 and 6000.The Four Strokes should run around 5800 as well.
