Verado 250's 2006 My port engine started idling at 1050 rpm at idle /neutral which is 200 rpm over spec and what the starboard engine runs at idle/neutral which is 850 rpm
Any instructions/comments on diagnosing various elements of the system to identify the cause without taking to dealer to plug in the diagnostic system?
Side note, these engines have "auto-sync" at +900 RPM and when in gear and above 900 rpm up to WOT the engines will sync and run the same rpm..so Im assuming the engine sync system/sensor is working correctly. Also no alarms or alerts come up on the gauges (all 52 engine sensor readings activated) to indicate a engine problem.
Thoughts?
Thoughts?
