I have a flat spot or hesitation on my Celebrity B200 fitted with a 350 Magnum 1991 and the mixture adjusters are not responding as they should so am going to rebuild it later this season. The Carb has the numbers:
170805623020 stamped into the body. Is this number relevant to the kit that I need to overhaul it and where is a good place to order one from?
The other question is, I noticed that one exhaust riser is quite hot at the top and the other is quite cool although below the top if you touch the side of the exhaust manifold are both the same temp/hot. Is this a common problem? The temp is normal according to the gauge but obviously I want to prevent something getting too hot. Any advice greatly appreciated.
