I assume you mean the spark is weak. Check the grounds under the coils. You want to see/hear blue loud snapping spark that jumps 7/16" gap. Buy or make a spark tester and test all plug wires at the same time to compare them.My spark are verry wet and my carb leak fuel.
Verify the float level is correct and the needle valve is sealing the fuel supply opening.The fuel is leak from the carb butterfly.
Thank for your reply, my spark work good, but the mixture is too rich, and when I turn the mixture screw, it's already reach, i check with colortune. the needle valve is good and i don't know if the level of the float is good? i have make a photoI assume you mean the spark is weak. Check the grounds under the coils. You want to see/hear blue loud snapping spark that jumps 7/16" gap. Buy or make a spark tester and test all plug wires at the same time to compare them. Verify the float level is correct and the needle valve is sealing the fuel supply opening.
Did you take it apart and look for a torn diaphragm? The pump will flood the engine if the diaphragm is torn.i have check fuel pump (OK),
The two diaphragm of the fuel pump ar good, no scratch, no hole, no torn. Do you thinks the problem can from the primer valve (choke)?Did you take it apart and look for a torn diaphragm? The pump will flood the engine if the diaphragm is torn.
