Below is a message that I posted on the Donzi forum, but have gotten no responses. Anybody here have any experience or suggestions?
Thanks,
Hello - I don't have a Donzi, maybe in the future, but I have inherited a 1988 20' bowrider from my father-in-law, that was powered with an AQ231B and a Volvo Penta 285 outdrive which is very similar to some early Donzis.
Engine block was freeze cracked big time, so repowering was in order. The solution turned out to be a 350 4bolt main block which grew to a 383, and a complete outdrive and cone clutch rebuild. The engine idles and runs and pulls smooth and after several different props(see below) the outdrive has proven to shift well, does not slip and doesn't leak. On to finding the correct prop.
Original 305 SBC, ran 49-51 MPH, with V-P alum props 15x19/5200rpm or 14x21/4700 rpm.
I knew that repropping would be required, so I started to collect props that fit this V-P long hub 285(1.61) outdrive.
1. V-P SS Ultra, 14x22RH
2. V-P SS Ultra, 14x24RH
3. V-P SS Ultra, 14x26RH
4. Hill SS 15x25LH
5. S&S LH Cleaver
Started with the the Ultra props, #1 and #2 above both had slipped hubs. What would you expect from ebay right?
Checked #3 above which had punch marks and had slipped also, 14x26, had it rehubbed and reconditioned by a shop that was highly recomended. It slipped with the rehub. I'm a little upset about this one. Are these props inherently difficult to rehub?
?? At lower RPMs 3000-4500, the 14x26 didn't slip but it caused the boat to pull hard to the left. Is this a characteristic of the these V-P Ultra props due to rake or some other characteristic? Never did get the outdrive torque trim tab adjusted to neutral, since at WOT the hub started to slip.
Next I installed the LH Hill SS prop, that I think is called the thrasher prop, but its difficult to be sure. This prop was NIB and ran great, no vibration, after adjusting the outdrive trim tab and achieved very neutral handling with this prop at any rpm. Ran WOT 5400rpm/58mph with this prop.
As I understand the cleaver prop needs to run partly out of the water, so i don't think I'll have much use for it.
I've read some posts on this forum about a Solas SS prop being recomended for the V-P outdrive but i'm not sure which model solas and there was talk that a 23 pitch size might be comparable to a 25 or 26 inch prop of other manufacturers.
??Any thoughts or recomendations on the adventure described above?
??Anybody need any SS Ultra props that require a rehub or a cleaver prop with a slight repairable ding(shipping damage)?
Thanks,
Thanks,
4. Hill SS 15x25LH
5. S&S LH Cleaver
Thanks,
