I have a 1980 Skipjack project boat. The Boat has a VP 290 outdrive. I was planning on building an engine because the boat did not come with a complete engine. Instead I found a donor boat that has a 1997 DP-S duoprop outdrive with a 5.7gpsplkd engine that only has 70 hours on it. The previous owner reports that he was starting the engine about every month until about 3 years ago. the donor boat has not been registered since 99. So I believe the engine hours. Now on to my questions.
1. What is involved in swapping the outdrive? ie bigger hole for outdrive unit or an adapter plate, or something else
2 what would you do with the engine? (oh by the way fresh water cooled) Turns over using a 3/8 ratchet. I am going to replace hoses, belts and things like that. but would you pull the heads and check cylinders, valve job.
when I check outdrive serial number, and engine serial number they both come back with a delivery date of 11/16/1996.
Any help would be greatly appreciated. Tried to upload pictures but I was not able to upload them.
