Replacing U joints on my 290 yikes
robj
"Hello,
While I have done l
"Hello,
While I have done lots of engine work, I have always tried to stay away from any gear box work. Well my U joints need changing on my 290, and I don't know anyone reliable who could do them for me at a reasonable cost. That is my first choice. I rather not take it to a shop since their hourly rate of $100 plus is too pricey for my budget. My last option is to do them myself. I have read the Seloc manual many times on how to do the job, but it is somewhat lacking in the details. I have no problem removing the upper gearbox and that is where my comfort level ends. How difficult is it to get the shaft out? I know they cannot be removed as it sits since there is not enough room to remove the caps. Also what else should I be doing while I have the upper out? Replace the seals on both the drive shaft and the shifter?
Any help or pointers would be greatly appreciated. Or if you know a good VP mechanic with reasonable rates in the Vancouver area, that would also be appreciated.
Thanx and have a great day
Rob."
Anybody have any suggestions? Or tips? Plan on doing it during the Easter weekend.
Rob.
Rob, If up for the task, one of us can walk you through this. Depending on what you are calling a 290, it can be very simple... some do not require re-shimming and/or re-setting of rolling torque when removing the bearing box and shaft! Again, depending on which drive you have.
If an early 290, the clamping collar bolts are considered a wet area thead......, I'd want to explain a few steps to you so you can avoid some hassles.
Maybe you can post a few images or a serial number.
FYI, I provide this service on the AQ series drives ..... and I am right below you in Oregon.
OK, this transmission uses an integral aluminum front collar/bearing box.... of which solves the corroded bolt thread issue for the most part....... but this transmission will use a crush sleeve for controlling the rolling torque value of the back-to-back main drive gear bearings.
So this part is a bit more techincal!
Are you comfortable with, or do you have any hypoid gear set-up experience?
NO, none at all. Which is why I am trying to avoid doing this job. One wrong preload and might as well start over, but it will be a lot more expensive.
Sent you a message earlier.
Thanx again and have a great day
Rob.
