"Hi all,
Fitted a new shutt
"Hi all,
Fitted a new shutter in outdrive exhaust pipe on a late 70's merc 3.0l, but its flaps dont fully close! See pic here: http://www.anthonybradley.plus.com/IMG_3463.JPG . Its a new original Mercruiser part (45586), and seems to be the correct size in every other respect but the metal brackets that it hangs on prevents the flaps from coming all the way back up unless pressed firmly from the other side.
I presume this isnt normal and that they should be closed in their at rest position? The only way I can think to fix this is to englarge the rectagular hole in the bracket downwards, so that the bar can sit lower allowing the flaps to come up a bit futher, but it seems wrong that I should have to do this (either that take a knife to the rubber but then it might noe be that watertight to prevent backflow).
Anyone seen this before, or got any other suggestions?
Thanks Anthony"
Fitted a new shutt
"Hi all,
Thanks Anthony"
