http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1979&hp=70&model=70973R
If you look at the difference between the shor and the long gearboxes they are mechanically different in the shift lever toe short shaft hase the 82 number you gave and it also has a cradel for the shift shaft yours doesnt. I couldnt find your part anywhere but if you call seaway if they dont have it no one does. You may want to consider changing the shift lever also as it may have caused the shaft to break?
