I have noticed that my blue-band 4 cylinder 50 hp (1979) motor misses at wot, starts well,planes but after a few minutes starts to miss. started the motor at home on muffs at night and after about 3 minutes noticed that the 2nd cylinder ignition coil is arcing between its center and the metal board that the coils are held to. I removed the coil and tested the primary and secondary with a voltmeter, ohms are in specification, however the ferrite magnets appear cracked on both sides. The other 3 coils are also withinn spec but have intact magnets. These coils are very hard to find i have tracked down an outboard wrecker that has a few but their condition is questionable. I guess the questions i have are
1) would a cracked magnet make the coil defective, and cause the miss at wot.
2) can i repair the magnets (if i cant find other ones)
3) can i use the new black coils as a substitute (spoke to the mercury dealer and he wasn't sure as they are for 1980 and newer motors.
regards Peter
regards Peter
