"I am looking for additional d
"I am looking for additional detail on removing a Volvo AQ240 engine from a Fiberform twin engine set up. Do I need to remove the complete 280 outdrive first? or can I just remove the upper gear sections as my Selec manual indicates? Do I separate the engine at the Flywheel housing to remove? or behind this? What do I need to worry about when I re-install for sealing the transom? I am assuming I should replace all bellows and water hose at this time, regardless of apparent condition. This is in a 1977 Fiberform Flying Bridge Cruiser. 27 X 10 wide, that has been sitting 10+ years. Thanks for any advice that comes."
