"I got both done, might send t
"I got both done, might send them out to Cliff to bench test just in case I did something horribly wrong.
There were some extra parts in each kit, just wondering if/where you guys used them:
- approx 2" thin round paper gasket
- small white plastic parts, I think they're
used for built in electric chokes.
- two small/black rubber o-rings with a lip
(small, maybe 1/2"). Looks like the press onto
something.
- 1" clear plastic ring/washer
I didn't replace the idle air tubes as I could see right through them. I also left the secondary shaft intact. The plastic cam looked fine.
I did re-bush the linkage. Very easy and definitely eliminates the play. Mark, thanks for suggesting I do this.
Bob
BTW - I received two kits and never opened the 2nd bag thinking it was the same. It had the instructions, ruler and specs. "
something.
Bob
