well I took the shift assembl
well I took the shift assembly apart and at the bottom front corner there is a black plastic piece with a lever in it that the shifter moves back and forth depending on whether your in reverse or forward or nuteral. I assume that its supposed to be spring loaded. I put it back into the neutral position and it fired right up. is that a part that I can buy?? and if not what does it actuall do?
