i'm looking for possible a
i'm looking for possible answers as to why the port side water flow coming out of the exhaust is noticeably less than the flow coming out of the starboard side exhaust. This is causing the engine to run at about 195 degrees too hot for my liking. I have traced the water flow from the intake into the v drive up into the water pump then into the heat exchanger coming out of the heat exchanger it splits with a t going to both elbows. I have replaced the impeller. Since I have a good flow coming out of the starboard side exhaust I thought that the only other possibility for the reduced flow on the port side was from a bad elbow. I replaced the port elbow the flow increased however it is still noticeabley less than the starboard side and the engine temp is still hovering close to 195. I cant seem to fiqure it out. Any ideas would be greatly appreciated. Oh yeah this is a 350 cid.
