yannicksjh
Hi, i have a 1993 Stingray 609zpx with a 4.3LX merc. Bought the boat last season and came accross these two problems that rarely occur. I'm having a hard time fiding what'swrong with it even from machenics since it rarely happens.
1. Problem 1 has happened twice last year and once this year so far. I used the boat on the previois day and then the very next day I go to start the boat and it doesn't. Its getting fuel and sparks just won't catch. Turns over like its starting when holding the key ON but just never starts. Its not flooded, battery(s) are fully charged. I tried for over an hour checking different stuff and nothing. then 1 last try before i leave and it starts??? turn it ON and OFF 10 times after that and it starts fine. Like i said this problem has only happened a few time when starting from cold and has never happenned on the water YET!. I know its hard to diagnose with out seeing but figured i'd ask.
2. This too rarely happens and not sure if its related to problem 1 but when moving at a regular speed anywhere from 15-35MPH the engine or something seems to stop for a second or two that catch back ON. Wife always says to quit doing that (or quit hitting the brakes, LOL). It never completly stalls out just enopugh to loose alot of speed and throw you forward a bit. I though it was maybe the prop hub slipping but its done it to two seperate props now. I don't know if the engine is loosing power for that second or what.
Just a note that there is newer spark plugs in and the problem was there before and after installing them.
Could it be the ignition coil going bad? Ignition sensor? interupter switch?
thanks in advance!
thanks in advance!
