a238killfish
found oil leak, if image I posted it is where I am pointing. my question is 1995 evinrude 200hp ocean pro , can I replace seal and rings without removing entire crank cover. the seal and rings are new but did not replace shaft o ring or sleeve. manual said not necessary unless worn. the powerhead gasket looked good.
