Question about water deflectors
factor696
"I have a 1981 Johnson 35 and
"I have a 1981 Johnson 35 and I'm just about finished changing out one of the pistons and I noticed that my water deflectors are breaking down and need to be changed. The water deflectors I bought seem to be too big to fit in between the cylinder wall space. I even tried grease to get them in, just don't seem to fit. My question is can I shave the rubber deflector down in diameter to get the to fit? Any info would be greatly appreciated..."
"No, do not shave down those d
"No, do not shave down those deflectors.
(Water Deflectors)
(J. Reeves)
Water deflectors are actually lengths of 3/8" outside diameter rubber hose, installed between the top cylinder and any cylinder beneath it, and also between the bottom cylinder and the block. The purpose of the deflectors is to have the water follow a definite path around the cylinder walls. Unfortunately the deflectors between the cylinders will at times swell sideways due to either a previous bad overheating problem, or simply due to age and salt corrosion. This causes a water flow restriction which usually allows the water to cool sufficently at low rpms but not at the higher rpms.
This hose material can be purchased reasonably at any automotive parts type store if you care to make your own, or you can purchase individual deflectors at any Evinrude/Johnson dealership at a somewhat higher cost.
Removing and installing them can be a hassle at times, but not always. I use a sharply pointed scribe with about 1/4" of the tip bent at a right angle whereas I can reach in, jab the tip sideways into the rubber, then yank it out. It's necessary to clean the seating surfaces where the ruber contacts the block with a small rat tail file to eliminate salt deposits etc. When installing the new rubber deflector, coat the deflector and the metal surfaces with WD40 which will act as lubrication to allow it to go in as easily as possible.
Make sure that you insert something into that deflector area before cutting and installing the deflectors if you make your own so that you will be certain that they are the right length and also that they will be seated properly. Usually a very small amount will be left extending about the block sealing area..... simply cut the excess off with a single edge razor blade.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
I have a 1996 johnson 150 I misstaking remove some of the water deflectors I don't know where to purches them?, I need a diagram showing their location. Any help would be appreciated.
I do not believe that a 1996 model 150 has deflectors.----So post the model # or pictures of your motor.----Need to have correct information to get the help you ask for.
(Water Deflectors)
(J. Reeves)
It's there a diagram show which hole need the on a j150exedb
J150exedb I removed them. On one side of the motor. The side is running hotter the the other head.
Has New water pump
What was " removed " on your engine?----Sealer or rubber hose " water deflectors " like found on V-crossflow engines?-----There are no deflectors shown on a 96 model 150 HP !
