1973browning
"I couldn't help reading t
"I couldn't help reading the post about the 454 swap and saw chiefalen's post about the bravo engine driven raw water pump setup. Question: Can a raw water pump be installed using the same principle of pulling water through drive in an alpha one r/mr standard drive? And if the raw water pump was removed from alpha one, would the external engine driven pump be able to pull water through drive in order to cool the unit and exaust system? What are the pros and cons if even possible! Thanks, Tom"
