bigjohnson
60hp johnson tj60tlsm 1990 four stroke
Carburetor
There is a small dia brass tube sticking into the throttle area
Forward side.
I can see the hole in one end of the tube but can not see the other end.
I'm assuming the hole is supposed to go all the way thru.
I use a sewing pin to try and go thru but it stops....like it's full of
Dirt or something.
Should I see daylight thru that hole or is it supposed to be blind?
How would you clean it? I don't want to damage this.
Motor will run but only for about a couple of minutes till it dies at
Half throttle.
Carburetor
Forward side.
Dirt or something.
Half throttle.
