Put new thermostat in
S
Sailormannj
Guest
" Pulled the head of 1982 15 h
" Pulled the head of 1982 15 hp Rude to replace upper mounts/
Should I replace the thermostat while it is apart? It is the orginal one, how long do they last? "
Sparky
How do you test it
Sparky
How do you test it in hot water?
"sailormannj; thremostats are
"sailormannj; thremostats are cheap and important,yes replace it.With the powerhead off replace the water tube grommets as they tend to swell and block off water flow!!
[email protected]"
" Jupiter,
About how much doe
" Jupiter,
About how much does a thermostat cost? I am thinking of replacing mine on my 15 Johnson. I'm also planning to rtemove and clean the bolts on the exhaust manifold and block. They are badly rusted. Is there anything I need to be careful of? Proper torque is 15-20 ft-lbs right? Is the sequence important? Thanks. "
