tboltmike
I have a 2009 130 ETEC. I can't seem to get all of the air out of the unit. The system uses the environmentally friendly oil.
Oil runs out of the fill plug when it is at full tilt, however, tilt is limited due to interference with the splash well rim.
I run the unit to full tilt crack open the fill plug and usually air comes out along with some oil. I open the manual release and as the engine approaches full lower air can be distinctly heard in the system. I run the tilt motor with the release still open in up and down position. The release is closed and the up button is activated. Often the engine will not raised with the as if the tilt motor is ventilating. It is necessry to push the down button before the up direction will prime. The engine is raised to full tilt and allowed to sit for seveal hours and again air can be heard coming out the fill plug.
I have been fighting this for quite a while. It is like the unit is sucking in air but there are no visible leaks.
Thanks for any input. Mike
