1999 Johnson 90 hp. I am having trouble getting my propeller shaft removed. I Have the bearing carrier out no problem. The clutch did not come out with it. The reverse gear came out and looks great. When I pull on the shaft theres some play from all the way in to about 2 inches out and then it hits a stopping point no matter how hard I pull on shaft. Its hitting something metal. I thought the drive shaft must be in the way but as I look at videos the prop shaft can be removed without removing the drive shaft. All videos show the saft just pulling out once the bearing carrier is removed. What Im trying to do is get to my clutch. I have no forward gear. I have reverse but no forward. Any help would be appreciated. Thanks
